Aktuelle Zeit: Do 15. Apr 2021, 15:08
 Betreff des Beitrags: Nike Air Max 1 Premium Navy/Gym Red
BeitragVerfasst: Di 17. Nov 2020, 04:52
Loaded onto the Nike Cyber Monday Deals release calendar today is the release of the latest "Magma Orange" iteration of the Air Max 1. Much like the 30th-anniversary editions that dropped in 2017, this retro is designed to look as close to the original 1987 release as possible. This pair dons OG-style color blocking with a white mesh upper, grey suede overlays, and vibrant orange accents seen on the mudguard and Swoosh. Grab a detailed look below.
Straying away from the traditional mesh and nubuck construction, this Nike Air Max 1 Premium Navy/Gym Red gets done in a smooth leather build all over the upper with White hitting the toe and side panels along with Wolf Grey overlays. Providing the pop of color is the addition of Spiral Sage (green) on the entire mudguard, Swooshes, upper eyelets, and the branding on the tongue and heel. A mini white Swoosh by the toe, a white midsole, and a black rubber outsole capm off the look on this Air Max 1.
As a follow-up to the “Limeade” theme, the Nike Black Friday 2020 will be offered next and adds on to the exclusive Powerwall drops from 2006. Flaunting the same Air pattern theme across its uppers, the model is also detailed with a strawberry motif on the tongues, as well as strawberry and lemonade graphics printed on the insoles. Finally, reflective materials are added to its base for higher visibility, while a white midsole and black rubber outsole top off the design.
Check Out The Official Photos Below, And Expect This Nike To Release In The Coming Weeks At Select Retailers.
https://www.nrunnersale.com/
