Read through the full text, You will learn about plant
growth lights with Samsung,you will know about the activities of 420light sale
1.
LED GROW LIGHT STRIPSDescription:
ECO Farm 250W/510W/700W/1000W series was the latest trend and most popular for its good design and ease of use.
It is a perfect top-lighting solution for commercial horticulture cultivation, or a full-cycle top-lighting solution for home hobbyists cultivating.
Product Features:
Save 100%-200% on lighting compared to other brands;
Industry top efficacy and light output - 2.9 μmol/j ;
Reduce HVAC and electricity costs by 50-60%;
Make you get 30% Higher Yield compare the traditional lamps, Increases revenue with better quality flower,s and higher yield(maximize crop yield by growing vertical).
Using high efficient and more reliable Samsung LM301H & Osram Chip horticultural LEDs.
3 Channel Dimmers, VEG switch, Bloom switch, UV switch separately controlled, Freely adjust the lamps according to different growing stages; VEG dimmer to control white light 5000K, one Bloom dimmer to control white light +red light ( 3000K+660nm), and UV dimmer to control UV 395nm.
Plug & Play design, horticultural can be easier!
Application: All those products are widely used in grow tents, house gardens, pot culture, hydroponics, greenhouse cultivation, etc.
Tailored spectrum can meet all your various application needs, easy for full growth cycle.
Perfect heat management, cool to touch.
Detail image
2.
LED LIGHT STRIPS WITH SAMSUNGDescription:
1. Use Samsung high bin LEDs, ultra high PPFD, replace HPS 600W and 1000W perfectly
2. 660W /900W/ multiple wattage optional
3. High lighting effect, 90% led grow light will be absorbed by plant, but to the tradition HPS light and MH light, its effect only 8% - 10%.
4. LED MODEL Meteor Storm is a high performance & affordable top-lighting solution for horticulture. Designed for applications requiring efficient,precise and uniform levels of PPFD.
Detail image
If you are interested in these products, you can click on our official website
ecofarm.ca to learn more.
